PowerShell Get-Process Returning Empty Value For The MainWindowTitle Property
  • pdwelliver
    • Jun 2021
    I wrote a simple PowerShell script to check and see if certain processes are running in Windows. I am running multiple instances of these processes which run in a command window so all of the processes have the same name but I need to differientiate between each instance of the running process. They are actually each connected to a different data stream and must be running all of the time. Fortunately, each of the command windows has a different title so I can use that to know which data set each cmd process is running. I am using Get-Process which includes a property MainWindowTitle that has what I want.
    I created the script and ran it in ProwerShell and it returned the information that I needed.
    PowerShell Script
    get-process | where-object { $_.MainWindowTitle -Like "ITWS Solace JMS 1.9.2" } | select-object ProcessName, mainWindowTitle
    Results Running Script In PowerShell
    ProcessName MainWindowTitle
    cmd ITWS Solace JMS 1.9.2
    I then modified the script so it would work in Zabbix as a UserParameter. I then tested this using the Zabbix_agent2.exe and got the same resultes with the value I needed in the MainWindowTitle property.
    UserParameter Setup In Configuration File
    UserParameter=IsITWSRunning,PowerShell -NoProfile -ExecutionPolicy Bypass -file D:/Zabbix_Scripts/IsITWSRunning.ps1
    PowerShell Script
    where-object { $_.MainWindowTitle -Like "ITWS Solace JMS 1.9.2" } | select-object ProcessName, mainWindowTitle | Write-Output
    Results using Zabbix_Agent2.exe
    IsITWSRunning [s|Using MainWindowTitle ITWS
    cmd ITWS Solace JMS 1.9.2]
    I then set up an item in Zabbix and tested it.
    Item Key: IsITWSRunning
    Type: Zabbix Agent
    Type Of Information Text
    The return value was empty.
    After a lot of additional testing I finally determined that when an item is set up to use a UserParameter that calls a PowerShell script using Get-Process it always returns an empty value in the MainWindowTitle property. This is despite the fact that when I test the same UserParameter using the Zabbix_Agent2.exe the data returned does contain a value in the MainWindowTitle (I also noticed that the MainWindowTitle is always 0 which is not true when testing with the Zabbix_agent2.exe).
    This is the PowerShell script I used to get all of the processes with the ProcessName 'cmd'.
    get-process | where-object { $_.ProcessName -Like "cmd" } | Format-List * | Write-Output
    I tested this running the script in PowerShell and then using the Zabbix_Agent2.exe and got the results below. It returned multiple processes but I am only showing the one running the process of interest.
    Results with Zabbix_Agent2.exe
    __NounName : Process
    Handles : 34
    VM : 16388096
    WS : 2887680
    PM : 1769472
    NPM : 3824
    Path : C:\Windows\system32\cmd.exe
    Company : Microsoft Corporation
    CPU : 0.03125
    FileVersion : 6.3.9600.16384 (winblue_rtm.130821-1623)
    ProductVersion : 6.3.9600.16384
    Description : Windows Command Processor
    Product : Microsoftr Windowsr Operating System
    PriorityClass : Normal
    HandleCount : 34
    WorkingSet : 2887680
    PagedMemorySize : 1769472
    PrivateMemorySize : 1769472
    VirtualMemorySize : 16388096
    TotalProcessorTime : 00:00:00.0312500
    BasePriority : 8
    ExitCode :
    HasExited : False
    ExitTime :
    Handle : 1696
    MachineName : .
    MainWindowHandle : 197186
    MainWindowTitle : ITWS Solace JMS 1.9.2
    MainModule : System.Diagnostics.ProcessModule (cmd.exe)
    MaxWorkingSet : 1413120
    MinWorkingSet : 204800
    Modules : {System.Diagnostics.ProcessModule (cmd.exe),
    System.Diagnostics.ProcessModule (ntdll.dll),
    System.Diagnostics.ProcessModule (KERNEL32.DLL),
    (KERNELBASE.dll)...}
    NonpagedSystemMemorySize : 3824
    NonpagedSystemMemorySize64 : 3824
    PagedMemorySize64 : 1769472
    PagedSystemMemorySize : 30496
    PagedSystemMemorySize64 : 30496
    PeakPagedMemorySize : 1802240
    PeakPagedMemorySize64 : 1802240
    PeakWorkingSet : 3354624
    PeakWorkingSet64 : 3354624
    PeakVirtualMemorySize : 20439040
    PeakVirtualMemorySize64 : 2199043694592
    PriorityBoostEnabled : True
    PrivateMemorySize64 : 1769472
    PrivilegedProcessorTime : 00:00:00.0312500
    ProcessName : cmd
    ProcessorAffinity : 65535
    Responding : True
    SessionId : 3
    StartInfo : System.Diagnostics.ProcessStartInfo
    StartTime : 12/15/2021 3:54:12 PM
    SynchronizingObject :
    Threads : {3724}
    UserProcessorTime : 00:00:00
    VirtualMemorySize64 : 2199039643648
    EnableRaisingEvents : False
    StandardInput :
    StandardOutput :
    StandardError :
    WorkingSet64 : 2887680
    Site :
    Container :
    I then tested using as an item in Zabbix. For all of the processes the MainWindowTile was empty.
    Results using item in Zabbix
    Handles : 34
    VM : 16388096
    WS : 2887680
    PM : 1769472
    NPM : 3824
    CPU : 0.03125
    HandleCount : 34
    BasePriority : 8
    ExitCode :
    HasExited : False
    ExitTime :
    Handle : 1640
    MachineName : .
    MainWindowHandle : 0
    MainWindowTitle :
    ProcessName : cmd
    Responding : True
    SessionId : 3
    Threads : {3724}
    StandardInput :
    StandardOutput :
    StandardError :
    Site :
    Container :
    Am I doing something wrong or is there a bug in Zabbix or some other issue? Is there any way I can get around this?
    I am using Zabbix Sever version 5.0.23 on Centos 7 with the Win64 Zabbix_Agent2 version 5.4.0 on Windows Server 2012 R2 Standard. I have tested this on other version of Window Server with the same results.
