IIS Monitoring Performance Issue through monitoring
  • piti87
    • Jun 2020
    • 23
    Good morning,
    I monitor the IIS (Template Microsoft IIS).
    We have 85 IIS sites and AppPools on the server.
    Unfortunately, that pretty much affects performance.
    In the task manager I keep seeing the powershells coming up (about 3-6 seconds)
    "powershell -NoProfile -ExecutionPolicy Bypass -File C:\sys_batch\zabbix\iis\get_sitestate.ps1 "website_1""
    etc., just for each AppPool.
    If I give the command
    So directly in a CMD (as admin), is it much faster and also uses significantly less CPU?
    The checks run every 5 minutes and then drain up to 90% CPU for about 2 minutes.
    Can I somehow lower the priority of the command/check, or tell it to only use 20% of the CPU?
    Is there a good approach?
    It wouldn't bother me if the check ran a total of one minute longer and used a little less CPU.
    If I output all states in one (1) Powershell session, this does not consume any CPU. I suspect the problem is launching a powershell session for each request. If a powershell script that uses the Zabbix would be open all the time, it would be worlds more performant.
    Zabbix 5.0.26
    Thanks!
