Problem with count with last function as data
  • MaxW
    • Aug 2022
    Greetings Zabbix Community,
    Trying to setup Zabbix to show incomming loggin by syslog log files.
    I try to create an trigger which triggers when the last value occurs in the last 5 minutes of x amount of items.
    The following expression is created:
    count(/Syslog server/log[/test.log,"((?:[01]\d|2[0123]):(?:[012345]\d):(?:[012345]\d)).(\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3})",,,,\2],5m,"like","last(/Syslog server/log[/test.log,"((?:[01]\d|2[0123]):(?:[012345]\d):(?:[012345]\d)).(\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3})",,,,\2],#1)")>3
    Also the following does not work:
    count(/Syslog server/log[/test.log,"((?:[01]\d|2[0123]):(?:[012345]\d):(?:[012345]\d)).(\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3})",,,,\2],5m,"like","{ITEM.LASTVALUE}")>3
    I'm sure the count function works like it should be, when i fill in de variable manually the item does trigger.
    But when i try to get a value out of an other items which is containing the data is seems to not work.
    Could someone tell me if this is even possible? Thanks and greetings.
  • roman.rajniak
    • Apr 2015
    Have you found solutions to this problem?
    I try this using dependent item to simplify name of item key for reason to eliminate escaping " in name, but no change. Also I try to use the item type for integer values. (No success)
    I think that fourth function count() parameter must be always a constant, and then for each ITEM.VALUE must exists trigger. - This isn't good way to solve comparing IP addresses in login.log .
      • 4970
      I kind of understand, what you want to do... but...
      You cannot create such a loop, that you feed items last value to a function as parameter...
      if you look on definitions
      count (/host/key,(sec|#num)<:time shift>,<operator>,<pattern>)​
      It is a "pattern" there, not a "{<MACRO>}, so you need to define a real pattern not a "lookup"...
      Same goes with ITEM.LASTVALUE.. there are places where you can use it, but this is not one of them. In certain cases you can use user or LLD macro there...
