triggers and template
  • dsipe
    • Oct 2006
    • 184
    I've created many template to monitor different kind of device.
    When creating a new trigger, can i use to name of a template instead of the one of the host using that template ?
    example:
    {template_name:status.last(0)}=2
    instead of
    {serveur_name:status.last(0)}=2
    The first one doesn't do anything ...
  • Vince2
    • Oct 2006
    • 40
    You use the name of the template for the trigger that is in the template. This trigger is then copied to all hosts using this template and when you look at the triggers of one of those hosts, you should see the corresponding trigger where the name of the template has been changed to the name of the host.
    • dsipe
      • Oct 2006
      • 184
      that's exactly what 've done. so that's ok.
      then i created a action on that trigger to get an email when it reached the ON state.
      I defined a mail media for the admin user and associate a "send message" action to that user on that trigger ... but dont get any mail, although the trigger is raised.
      Using mail command on my linux server running zabbix server worked fine.
      Dont known where to look to get it work
