Hi guys,
I am configuring traps by following below link.
when i try to run below command, i have error message as shown below.
Command
snmptrap -v 1 -c public 127.0.0.1 '.1.3.6.1.6.3.1.1.5.4' '0.0.0.0' 6 33 '55' .1.3.6.1.6.3.1.1.5.4 s "eth0"
Error Message
No log handling enabled - turning on stderr logging
Cannot rename /var/lib/net-snmp/snmpapp.conf to /var/lib/net-snmp/snmpapp.0.conf
Cannot unlink /var/lib/net-snmp/snmpapp.conf
read_config_store open failure on /var/lib/net-snmp/snmpapp.conf
I check the location /var/lib/net-snmp/ and notice there is no snmpapp.conf.
Does anyone encounter this before ? If yes, kindly advise what cause this message.
Thank you very much.
Command
Error Message
