Zabbix Package for AIX Servers
  • Singularity
    • Aug 2020
    • 81
    Can some tell me if we have pre-compiled package of zabbix for AIX servers on zabbix repository.
    Thankyou.
  • Answer selected by Singularity at 30-08-2022, 15:43.
    cyber
    • 4969
    No, there is not.
      • 4969
      No, there is not.
      • Singularity
        • Aug 2020
        • 81
        So the only way to create zabbix setup for AIX servers is by using source and make.
        Thankyou cyber for quick reply.
          • 4969
          You can ask support. They say its supported platform, so it has to be tested there.. So they might be able to provide you with something. That way I did obtain some weird versions of Solaris agents once, which were not available publicly for download..
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            There are some versions of Zabbix agents here: https://www.zabbix.com/download_agen...&show_legacy=0
