Grafana integration
  • Coastal IT Support
    • Sep 2019
    Grafana integration
    Hi all,
    Has anyone had much luck with the newer versions of Zabbix and Grafana? Previous versions never had any issues. Now we have upgraded to Zabbix 6.2.1 and Grafana 9.0.2 we cannot get the MySQL datasource to work
    Checked and tried IP, same server its hosted on.
    Changed the below for security - made no difference.
    User Permission
    The database user should only be granted SELECT permissions on the specified database & tables you want to query. Grafana does not validate that queries are safe so queries can contain any SQL statement. For example, statements like USE otherdb; and DROP TABLE user; would be executed. To protect against this we Highly recommmend you create a specific MySQL user with restricted permissions. Checkout the MySQL Data Source Docs for more information.
    Keep getting the error
    db query error: failed to connect to server
    Running the below plugin and whitelisted in the config file.
    Alexander Zobnin
    Dependencies:
    Grafana >=8.3.0​
    Any help appreciated.
  • 18dani
    • Aug 2022
    Try changing http://127.0.0.1/zabbix/api_jsonrpc.php​ into --> http://127.0.0.1/api_jsonrpc.php, had the same problem but I was using Zabbix as datasource not MySQL.​
