Hi guys,
How can I set our servers to start zabbix_agentd upon reboot?
This is on a CentOS box.
thank you
I have it running on CentOS 4.4
Chris riley did the script I am using...I think the only thing to be aware of is the location of the pid file...you need to move it to /tmp then the script works.
Hi Grabber,
Thanks, that would be great if you have the script. I had read one posted a while back on the forums here, but there was a note that it may not have been working properly.
Hi Grabber,
