Allow zabbix to have an inventory of softwares installed on a machine
  • jerometeano
    • Sep 2022
    Hi. Im a newbie in managing and configuring zabbix. I need to configure zabbix to monitor and have an inventory of all the software installed on my server. Can someone guide me on how to do this? Thank you.
    system.sw.packages[<package>,<manager>,<format>]
    Listing of installed packages. Text package - all (default) or a regular expression
    manager - all (default) or a package manager
    format - full (default) or short
    Supported platforms:
    Linux.
    Lists (alphabetically) installed packages whose name matches the given package regular expression (all lists them all).
    Example:
    => system.sw.packages[mini,dpkg,short] → python-minimal, python2.6-minimal, ubuntu-minimal
    Supported package managers (executed command):
    dpkg (dpkg --get-selections)
    pkgtool (ls /var/log/packages)
    rpm (rpm -qa)
    pacman (pacman -Q)
    If format is specified as full, packages are grouped by package managers (each manager on a separate line beginning with its name in square brackets).
    If format is specified as short, packages are not grouped and are listed on a single line.
    Supported since Zabbix 2.0.
    Works only on linux.
    • jerometeano
      • Sep 2022
      Currently looking at how to configure items. Thanks for the response.
      • jerometeano
        • Sep 2022
        Hi.
        Is there a way to present these values at a more readable manner? The result is like a raw version of data from the system.sw.package item key for zabbix agent. Thanks.
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          Unfortunately, not out of the box.
          • jerometeano
            • Sep 2022
            Hi guys,
            Is it possible to add this software installed package in hosts inventory so that it can viewed as additional details for the hosts? Thanks.
              "populate inventory" is an option, but I am not sure if there is a field big enough to contain all of that...
              • dimir
                Zabbix developer
                • Apr 2011
                • 1080
                Meanwhile, you might want to go and vote for https://support.zabbix.com/browse/ZBXNEXT-336 :-)
