Zabbix sender / Zabbix trapper behavior
  • Koustubh
    • Mar 2016
    I have a process which collects data from multiple instances of same process for 5 minute window. It then adds those values, attaches starting timestamp with them and via file, sends them to zabbix server using zabbix_sender.
    format of values stored in file is
    "hostname" "record_count" "1457560916" "1000"
    item "record_count" is defined as zabbix trapper.
    A file can have values for different 5 minute windows in past.
    I noticed that if I export two values with same timestamp, zabbix server averages them. (observed via graph)
    for example, if I export 1000 and 1500 with same timestamp, I am expecting it to be 2500 but zabbix shows 1250.
    Is there a way to get zabbix to add the multiple values received for same time?
    Is there any other way to handle this scenario?
    I need zabbix to sum all the values received for the item for same timestamp.
    Thanks for your help.
