cannot connect to IPMI host: [33554445] Unknown error 33554445
  • mckinnonsc
    • Nov 2020
    Trying to get IPMI working for Asus ASMB9-iKVM (Asus Server IPMI)
    Ubuntu 20.04 LTS
    Zabbix Version 5.2.4
    Zabbix Agent Version 5.2.4
    With debug 4 I can only see this in the logs regarding ipmi.get (captured by executing the item ipmi.get manually)
    > tail -f /var/log/zabbix/zabbix_server.log | grep ipmi.get -C 50 -A 50
    018059:20220906:122401.449 zbx_setproctitle() title:'trapper #4 [processing data]'
    4018059:20220906:122401.449 trapper got '{"request":"item.test","data":{"type":"12","proxy_hostid":"0","key":"ipmi.get","interface":{"address":"hvc02.ipmi.noddy.mckinnonsc.vic.edu.au","port":"623","type":0},"host":{"hostid":"12753","ipmi_authtype":"-1","ipmi_privilege":"2"}},"sid":"de11d0eec7507352d43bb3ddaf03781e"}'​
    ipmitool works fine
    > ipmitool -H hvc02.ipmi.noddy.mckinnonsc.vic.edu.au -U zabbix -P password -L USER sensor
    CPU1 Temperature | 41.000 | degrees C | ok | 0.000 | 0.000 | 0.000 | 89.000 | 92.000 | 95.000
    TR1 Temperature | 19.000 | degrees C | ok | 0.000 | 0.000 | 0.000 | 37.000 | 40.000 | 60.000
    +VCORE1 | 0.963 | Volts | ok | 0.495 | 0.522 | 0.585 | 1.485 | 1.521 | 1.602
    +VSOC1 | 0.864 | Volts | ok | 0.558 | 0.594 | 0.666 | 1.206 | 1.260 | 1.323
    +VDDIO_ABCD_CPU1 | 1.212 | Volts | ok | 0.960 | 1.020 | 1.080 | 1.320 | 1.380 | 1.440
    +VDDIO_EFGH_CPU1 | 1.212 | Volts | ok | 0.960 | 1.020 | 1.080 | 1.320 | 1.380 | 1.440
    +12V | 11.948 | Volts | ok | 9.628 | 10.208 | 10.788 | 13.224 | 13.804 | 14.384
    +5V | 5.040 | Volts | ok | 4.008 | 4.248 | 4.512 | 5.496 | 5.760 | 6.000
    +5VSB | 5.184 | Volts | ok | 4.008 | 4.248 | 4.512 | 5.496 | 5.760 | 6.000
    +3.3V | 3.280 | Volts | ok | 2.640 | 2.800 | 2.976 | 3.632 | 3.792 | 3.968
    +3.3VSB | 3.328 | Volts | ok | 2.640 | 2.800 | 2.976 | 3.632 | 3.792 | 3.968
    VBAT | 3.040 | Volts | ok | 2.400 | 2.560 | 2.700 | 3.640 | 3.800 | 3.960
    FRNT_FAN1 | 9500.000 | RPM | ok | 0.000 | 400.000 | 400.000 | 22500.000 | 23700.000 | 25000.000
    FRNT_FAN2 | 9500.000 | RPM | ok | 0.000 | 400.000 | 400.000 | 22500.000 | 23700.000 | 25000.000
    FRNT_FAN3 | 9500.000 | RPM | ok | 0.000 | 400.000 | 400.000 | 22500.000 | 23700.000 | 25000.000
    I'm aware of https://support.zabbix.com/browse/ZBX-6139 but I cannot install or recompile with ssl enabled (if this is even required in 20.04 anymore?) as the first command fails
    > /tmp$ apt-get source openipmi
    Reading package lists... Done
    E: Unable to find a source package for openipmi​
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Check your /etc/apt/sources.list, do you have an "deb-src" entry there? If not, add (or uncomment) it, run apt update and repeat.
    • mckinnonsc
      • Nov 2020
      I never replied, I'm so sorry! This fixed my issue, thanks so much.
