Zabbix encryption problem
  • ivan.a
    • Sep 2022
    Hi Everyone,
    I have a problem with setting up encryption on Windows Server 2019.
    When I set up encryption on the specified server, the Zabbix agent stops sending data to the Zabbix monitoring server.
    I have checked the encryption parameters several times, and I have adjusted the encryption on many servers and I have never had this problem.​
    An error appears​: 4204:20220901:100601.256 active check configuration update from [nadzor2.sistemas.hr:10051] started to fail (TCP successful, cannot establish TLS to [[nadzor2.sistemas.hr]:10051]: SSL_connect() I/O error: [0x00002746] An existing connection was forcibly closed by the remote host.)
    Just to mention, the Zabix monitor server is located in a different country with different regional and time settings than the server on which I set up encryption. Windows 2019 server on which i want to set up encryption, was updated.
    A VPN connection is established from the Zabbix server to the monitored servers.​
    Please help me with this.Thanks!​
