Ignoring selected drives on Filesystem detection
  • Jason
    • Nov 2007
    • 431
    I'm trying to add another filter to the drive detection to ignore certain drives.
    I'd like to do it by creating a macro on the host called {$IGNOREDRIVES} and then the value to something like D to ignore D: or DE to ignore drives D & E.
    I've tried adding this to the filter list, using a custom reg ex but it doesn't seem to work
    the reg expression is ^{$IGNOREDRIVES}$ and the result is set to false. i.e. if it's not found then it's ok.
    Are we allowed to use MACROS in this way? I'm on 2.4.5
  • jan.garaj
    • Jan 2010
    • 506
    yes - https://www.zabbix.com/documentation...ed_by_location
