Agent Server active check not working
  • Xyue
    • Jan 2016
    • 93
    Hi guys,
    I'm trying to use agent to monitor server. Both agent and server are install in same machine. I keep getting below message from agent and server log
    zabbix_agent.log
    no active checks on server [127.0.0.1:10051]: host [zabsrv.xxx.com] not found
    zabbix_server.log
    cannot send list of active checks to [127.0.0.1]: host [zabsrv.xxx.com] not found
    Have searched on forum and google and most of them advise is the hostname issue. I'm quite sure my hostname are correct. Below is the configuration.
    /etc/zabbix/zabbix_agentd
    ServerActive: 127.0.0.1
    Hostname:zabsrv.xxx.com
    [root@zabsrv zabbix]# hostname
    zabsrv.xxx.com
    [root@zabsrv zabbix]# netstat -ltn
    Active Internet connections (only servers)
    Proto Recv-Q Send-Q Local Address Foreign Address State
    tcp 0 0 0.0.0.0:10050 0.0.0.0:* LISTEN
    tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN
    tcp 0 0 :::10050 :::* LISTEN
    tcp 0 0 :::10051 :::* LISTEN
    Would appreciate if anyone can point out what caused it unable to work properly.
    Thank you.
  • glebs.ivanovskis
    • Jul 2015
    • 237
    Check hostnames configured in Zabbix frontend and in agent's configuration file. They should be identical.
    • Xyue
      • Jan 2016
      • 93
      I checked again my agent config file and notice that i did not include the port. Once i added in the port, server able to send out the active check list but now the agent seems having some error.
      Based on the log, I saw below error message:
      cannot parse list of active checks: cannot parse as a valid JSON object: invalid object format, expected opening character '{' at: 'ZBX_NOTSUPPORTED'
      Can you advise where should i check for this error message ?
      Thank you.
      • Atsushi
        • Aug 2013
        • 2028
        What version of Zabbix server are you using?
        What version of Zabbix agent are you using?
        • Xyue
          • Jan 2016
          • 93
          Below is the information needed:
          [root@zabsrv ~]# zabbix_agentd -V
          Zabbix Agent (daemon) v2.4.7 (revision 56694) (12 November 2015)
          Compilation time: Nov 13 2015 05:35:30
          [root@zabsrv ~]# zabbix_server -V
          Zabbix server v2.4.7 (revision 56694) (12 November 2015)
          Compilation time: Nov 13 2015 05:31:52
          [root@zabsrv ~]# zabbix_agent -V
          Zabbix agent v2.4.7 (revision 56694) (12 November 2015)
          • Atsushi
            • Aug 2013
            • 2028
            What are you set to the ServerActive?
            • Xyue
              • Jan 2016
              • 93
              I set it to 127.0.0.1:10050 as i installed the agent and server in same server.
              • Atsushi
                • Aug 2013
                • 2028
                Port number 10050 is the port number to use to access from Zabbix server to Zabbix agent.
                Port number 10051 is the port number to use to access from Zabbix agent to Zabbix server.
                Please use port 10051 to ServerActive.
                ex.
                ServerActive=127.0.0.1:10051
                or
                • Xyue
                  • Jan 2016
                  • 93
                  When i tried to replace it with your suggestion, I got below error message
                  Zabbix_server.log
                  22431:20160315:135500.051 cannot send list of active checks to [127.0.0.1]: host [zabsrv] not found
                  Zabbix_agent.log
                  14962:20160315:135500.051 no active checks on server [127.0.0.1:10051]: host [zabsrv] not found
                  Can you advise what is the correct way to set in the server and agent config file ?
                  Thank you very much
                  • Atsushi
                    • Aug 2013
                    • 2028
                    Did you register the host named 'zabsrv' by Web frontend?
                    (case sensitive)
                    • glebs.ivanovskis
                      • Jul 2015
                      • 237
                      Now create host "zabsrv" as described here.
                      • Xyue
                        • Jan 2016
                        • 93
                        Based on the log file, I think i can assume the agent active check is running now and did not see the error message in the log file.
                        Actually i did create a host for zabbix server but the hostname was differ from what i configure for web interface.
                        [root@zabsrv ~]# tail /var/log/zabbix/zabbix_agentd.log
                        17285:20160315:145146.924 agent #0 started [main process]
                        17287:20160315:145146.924 agent #1 started [collector]
                        17288:20160315:145146.925 agent #2 started[listener #1]
                        17289:20160315:145146.925 agent #3 started[listener #2]
                        17290:20160315:145146.925 agent #4 started[listener #3]
                        17291:20160315:145146.925 agent #5 started [active checks #1]
                        [root@zabsrv ~]# tail /var/log/zabbix/zabbix_server.log
                        17379:20160315:145158.353 server #25 started [snmp trapper #1]
                        17381:20160315:145158.353 server #26 started [proxy poller #1]
                        17373:20160315:145824.676 item "zabsrv:log[/var/log/rsyslog.log]" became not supported: Accessible only as active check.
                        Thank you very much for your help and support.
                        Appreciate as you help me a lot on this.
