LDAP authentication
  • thkam
    • Sep 2022
    LDAP authentication
    Hi!
    After upgrading from 5.2 to 6.2.2 there seems to be something wrong with LDAP authentication.
    We are using StartTLS to bind to the server and while I can bind from the Test button in Authentication > LDAP settings, users can not login
    It also seems that hitting the update button does not keep the updated configuration...
    Thanks!
    Thomas
  • thkam
    • Sep 2022
    Ok so I just deleted the Ldap configuration and recreated it. Seems to be OK now
