Problem after upgrade to 6.2
  • VitalyL
    • Sep 2022
    Stuck with a problem with Zabbix 6.2 soon (about a month and a half) after update (to 6.2):
    When adding a template to a new host, discovery rules in this template don’t execute automatically, works if executed manually, but discovers just about a half of items it should (tested with the same template with a freshly installed zabbix same version)
    As a side note: working with received data has gone haywire as well, for example creating a graph with more that 10 items results in either empty graph (on preview) or graph without legend (no matter of legend checkbox status)Stats:
    1. Zabbix on Oracle Linux 8, DB TimescaleDB 13
    2. 1011 hosts monitored with 31188 items.
    3. Zabbix agent version 6.2.1
    Zabbix server version 4.4 was install 3 years ago with TimescaleDB 12, about a year and a half ago was update to Zabbix 5.4 and timescaledb 13 been working well with such config. Problems started after update to Zabbix 6.2Any suggestion on cause/resolve will be appreciated. Thanks in advance​
  • felipe.pimentel
    • Sep 2022
    In version 6.2.1 the error "TimescaleDB version not supported. Must not be greater than 2.6" appears.
    Now in version 6.2.3 it says "TimescaleDB version not supported. Must not be higher than 2.7".
    Because TimescaleDB is at version 2.8.​
    Waiting for compatibility update from zabbix too.
