Email Alert be resent in a regular interval until problem is resolved
  • SonyRaymond
    • Sep 2022
    May I know if application monitoring in Zabbix can monitoring status code returned from a HTTP URL and send an email alert in case HTTP status code 400 is received ?
    Also will the email alert be keep sending out in a regular time interval until HTTP status code returns to 200 normal ?
    Thanks for your kind attention,
    Raymond
  • tim.mooney
    • Dec 2012
    • 1430
    Yes to the first question.
    Yes to the second question, but it depends upon how you configure it. The most common configuration would do exactly what you're asking for.
