After failure, had to restore zabbix server v. 4.0.34 configuration (on mysql db).
SCHEMAONLY was restored for these tables:
acknowledges
alerts
auditlog
auditlog_details
history
history_log
history_str
history_str_sync
history_sync
history_text
history_uint
history_uint_sync
item_rtdata
problem
problem_tag
task
task_acknowledge
task_check_now
task_close_problem
task_remote_command
task_remote_command_result
trends
trends_uint​
Other tables restored completely.
I faced the issue that pre-fail Problems are missing in problems table and web interface.
There are many Triggers in PROBLEM state, but those don't show up/come to Problems table.
Enabling/disabling Trigger, Host does not solve the issue.
Found workaround: clone(recreate) triggers or whole hosts, but for about 300 hosts with 11K items and 5K triggers it does not look as a good alternative.
Is there a way to force Triggers to be (mass) reprocessed and Problems recreated?
Or maybe there is some kind of mark in zabbix table(s) that the Trigger is already "mentioned" in Problems? (Then such a mention might be deleted in my case).
acknowledges
alerts
auditlog
auditlog_details
history
history_log
history_str
history_str_sync
history_sync
history_text
history_uint
history_uint_sync
item_rtdata
problem
problem_tag
task
task_acknowledge
task_check_now
task_close_problem
task_remote_command
trends
trends_uint​
