Server stack with - SSL_shutdown() with IP_ADDRESS set result code to 5
  • Amiram
    • Feb 2021
    • 68
    Hey all,
    I'm monitoring around 3K servers with my zabbix server (version 6.2.0) in a docker.
    After few minutes the server running (after restart) the server "stop responding" and monitor the hosts and all the messages in the log file are:
    TIMESTAMP SSL_shutdown() with IP_ADDRESS set result code to 5:
    For all the IP addresses of the hosts it monitor.
    It used to work and just stopped
    Any ideas?
    P.S
    All the hosts are running psk encryption with the server.
  • Amiram
    • Feb 2021
    • 68
    I'm having the same issue.
    Anyone..?
    • Markku
      • Sep 2018
      • 1784
      Have you upgraded your Zabbix? https://support.zabbix.com/browse/ZBX-21310
      Markku
      • Amiram
        Amiram commented
        Its say that they release a fix at version 6.2.1rc1 and I'm running Server version 6.2.2 and it not fixed yet.
        Do you know if this fix include in the 6.2.2 or in the 6.2.3?
        And what about the zabbix-agent2?
        The fix is not include there as well?
