Discovery: how to check against the max value over all objects
  • mbrackeva
    • Feb 2016
    • 27
    Consider this scenario:
    • I set up a discovery of all local disks on Linux servers, on of the item prototypes is "Busy" (disk busy in %).
    • I can successfully create triggers against this item prototype.
    • I now want to create a trigger that checks the highest Busy value over all disks. In other words: create an event when the disk with the highest Busy value has a busy value over 90%.
    Any ideas if this is possible?
