trigger for postgresql folder size
  • majed17
    • Oct 2019
    • 21
    Peace, there is a template
    vfs.dir.size[/srv/pgsql/13/pg_wal] units b, every 2 mins, and i made a trigger for it as last(/pg_wal/vfs.dir.size[/srv/pgsql/13/pg_wal])>4G but it not working correctly...
    i need to report a problem if the size is less the 4 GB or higher than let's say 13GB, how to do that?
