Zabbix 6.2: SNMP MIBS
  • andreagx
    • Oct 2021
    • 29
    Hello guys,
    I love Zabbix but I'm facing problems, specially with Fortigate's SNMP template.
    So, I would like to learn how to create template or how to use vendor's MIBS files.
    What do you suggest to me?
    TNX
  • jtnfoley
    • Mar 2022
    • 82
    mib2zabbix to create a template from MIBs. There's a learning curve but it works... it will create a LOT of unneeded data items that you'll have to delete from your template.
    I have much Fortinet hardware and varying success with different community templates. My best success has been with "Template Net Fortinet FortiGate SNMP" - From its' Description data:
    Zabbix Template for Fortinet FortiGate
    URL: https://github.com/mbdraks/fortinet-zabbix
    Author: Michel Barbosa
    Version: 2.1.0
    Exposes information obtained from the following MIBs (import is not required):
    - SNMPv2-MIB
    - IF-MIB
    - EtherLike-MIB
    - FORTINET-CORE-MIB
    - FORTINET-FORTIGATE-MIB
    This template also incorporates the exact same data collected by the following default templates (no import or link required):
    - Generic SNMP
    - Interfaces SNMP
    - EtherLike-MIB SNMP​
    • andreagx
      • Oct 2021
      • 29
      Thank you for your reply
      I'm using that template. The issue is in the photos.
      The WAN bandwith is a Gigabit ethernet but Zabbix shows max 500Mbit. There are too many $1 and is not clear what is what.
      If I do a speed test from a client, it's shows 900/900 Mbit, but Zabbix shows always 500Mbit as a max value.
      In photo Capture3, why the upload is divided on two or more value? The graph do not show the sum.
