Check for an item value if it is from today
  • markfree
    • Apr 2019
    • 875
    I have a prototype item that basically receives a file write timestamp in unixtime which indicates its last arrival time.
    Everyday a new file is created with the same name and Zabbix receives its arrival timestamp.
    Now, I wanted to create a trigger that checks if there is a new file arrival time for the current date.
    For now, my raw logic is something like this:
    Between 00h and 02h30 there should be a new file coming, and should it not arrive, it is a delay; therefore, an event should be created.
    if time() > 023000 and last(file timestamp) <> today, then trigger alarm.
    I'm not sure how to create that trigger.
    How should I read the date from that item (timestamp value)?
  • markfree
    • Apr 2019
    • 875
    For now, I have tried something like this.
    nodata(/host/key[{#NAME.SUFFIX}],4h)=1
    and
    time()>040000
    and
    dayofweek()>=2
    and
    dayofweek()<=6
    But this expression does not account for "Discard unchanged" preprocessing, which my item uses.
    So, it always triggers after 04h.​
    Any thoughts?
