How to create a template for an HP printer?
  • maximus21gg
    • Sep 2022
    I need to figure out how to write an hp laserjet pro m203dn xml template from scratch to keep track of all the basic data like how much toner is left, cover open etc if possible. I have the output of the command "snmpwalk -v 1 -c public 10.113.1.30" but I don't know what to do next. I'm a complete noob at this.
  • marianogedisman
    • Oct 2021
    • 78
    Try this: https://github.com/Sean-Bradley/SNMP2ZABBIX
    • maximus21gg
      • Sep 2022
      Originally posted by marianogedisman
      I tried, it doesn't work, or I don't understand anything about it. Is there any easy to understand instructions?
    • marianogedisman
      • Oct 2021
      • 78
      I was able to pull a template with SNMP2ZABBIX​ very easily.
      • maximus21gg
        • Sep 2022
        well, I'll try again. thanks, I assumed that this script is the most correct option
        • marianogedisman
          marianogedisman commented
          It's not a very easy thing to do. I'm still fighting with this script because it's not pulling all of the OIDs from the printer.
          It depends on what you need to do. In my case: I try to pull as many OIDs as possible with this script, and if I'm missing something I just user snmpwalk and snmpget if necessary.
          Let me know if you got it to work. I'm also stuck with the preprocessing part, as SystemUpTimes are not working for me at the moment.
          Best of luck!
      • tim.mooney
        • Dec 2012
        • 1436
        Scripts like that are a way to automate creating items and sometimes triggers, when you need to collect a huge amount of data.
        If you only need a few items, it's often very easy to just look through the MIB and decide what OIDs you want to gather. Creating a template isn't magic, it's just a collection of things like items, triggers, etc. that you can easily apply to a host. Writing the items "by hand" sometimes gives you a better understanding of what's going on than just using an automated tool. Of course, if the tool is working, its output can be used as another source of information and ideas for how to write your own items.
        • maximus21gg
          • Sep 2022
          I need to figure out at least a little bit which oids are responsible for what. I don’t really rummage about this, I was given such a task to monitor the printer in zabbix
          • tim.mooney
            • Dec 2012
            • 1436
            In that case, you can often look at templates for other printers from the same manufacturer. There will be model-specific differences, but a lot of the most common OIDs will often be the same between different models.
              • 4990
              There is a bit of info to digest.. http://www.circitor.fr/Mibs/Html/H/H...COMMON-MIB.php
