GLPI API - Zabbix Help
  • maes_91
    • Sep 2022
    Hello
    I am trying to create automatically GLPI Tickets (API) from Zabbix.
    I found this link but I don't understand how to complete the In Zabbix
    Example what is glpi_url
    3. Create a Zabbix user and add Media with the GLPi media type. Though a "Send to" field is not used in GLPi webhook, it cannot be empty. To comply with frontend requirements, you can put any symbol there. Make sure this user has access to all hosts for which you would like problem notifications to be converted into GLPi problems.
    4. Set up a global macro {$ZABBIX.URL} with URL of current zabbix. Please notice that HTTPS will be used by default if HTTP/HTTPS schema is not present in the URL.
    Thank you
