Zabbix monitoring SQL databases on 1300 servers
  • Stephen J Capita
    • Mar 2022
    • 13
    I am in the process of migrating all our alerting from a very old product called server vantage to zabbix. I have most things moved over, but looking at some custom alerting we had for sql databases. I have found this user created script which would be ideal. But just need help getting it setup. It mentions a powershell script but I see no information on it. Here is the template in question.
    https://share.zabbix.com/templates/d...very-lld/#body
    When I import it I see I need to set the macro with the sql instance name, but I dont know about the powershell script.
    We use an SQL instance name of SQL Server (MSSQLEXP2016) so this is what I have defined in my macro:
    Click image for larger version  Name:	image.png Views:	0 Size:	10.5 KB ID:	452408
    ​This is the discovery key, but it talks about a powershell script. I am not sure where to set this
    Click image for larger version  Name:	image.png Views:	0 Size:	37.9 KB ID:	452409
    When I try to add the template to a server, it comes back with unknown metric windowsdb.discovrey.
    I am running zabbix 6.0.9 lts on centos 8 stream​
    I guess you need to add that script to hosts and update it with correct instance name. And then also add UserParameter (UserPArameter=windowsdb.discovery,/path_to_your_ps1_script), which calls that script.
    • Stephen J Capita
      • Mar 2022
      • 13
      Cheers for the help, after further investigation, I found that the counters I needed were perfmon counters. So I am in the process of setting up my own custom template with all the prefmon counters I need.
