Problem with deploy new zabbix.
  • ZeroOnePL
    • Apr 2022
    • 12
    Hi i have problem
    I have new UBUNTU server 22.04
    I instal zabbix from this
    https://www.zabbix.com/download?zabb...ubuntu&os_vers ion=22.04&components=server_frontend_agent&db=pgsq l&ws=apache
    But when i try step C : sudo -u postgres createuser --pwprompt zabbix​
    I have error like this.
    sudo: unknown user postgres
    sudo: error initializing audit plugin sudoers_audit
    • 4961
    User postgres is usually created while installing Postgres DB. Did you do that?
    • ZeroOnePL
      • Apr 2022
      • 12
      Click image for larger version  Name:	Screenshot_465.png Views:	1 Size:	23.7 KB ID:	452522
      I use this command: apt install zabbix-server-pgsql zabbix-frontend-php php8.1-pgsql zabbix-apache-conf zabbix-sql-scripts zabbix-agent​
      And all go succesfull so i think Postregs is installed.
        • 4961
        I doubt... You are installing Zabbix components with that command. You are not installing PG or apache... Try to resolve prerequisities at first. Install DB engine and webserver etc..
        • ZeroOnePL
          • Apr 2022
          • 12
          ok if zabbix has documentation on how to do this​?
          • ZeroOnePL
            • Apr 2022
            • 12
            Ok i Install postregs and apache.
            I end steps C,D and E but when i try to login to zabbix i have apache page.
            Click image for larger version  Name:	Screenshot_466.png Views:	0 Size:	64.5 KB ID:	452530
            EDIT: Ok all works. you can close this.
            • Ravindra
              • Oct 2022
              Can some please post steps to upgrade zabbix ubuntu 16.04 to 18.04
                • 4961
                Platform upgrade is not a Zabbix topic. You should ask that from Ubuntu specific places.
