If MSSQL Service is Down for 10 Minutes
  • techmattr
    • Sep 2022
    • 39
    last(/SERVERNAME/net.tcp.service[tcp,{HOST.CONN},{$MSSQL.PORT}])=0
    How would I add a time constraint to the MSSQL service availability alert? We have backups that run nightly and cause the service to become unavailable for anywhere between 30 seconds and 5 minutes and we end up getting alerted nightly for something that recovers on its own. So I'd like to only be alerted if the service is unavailable for 10 minutes.
  • Answer selected by techmattr at 12-10-2022, 20:39.
    Hamardaban
    • May 2019
    • 2714
    count(/SERVERNAME/net.tcp.service[tcp,{HOST.CONN},{$MSSQL.PORT}],10m,"gt",0) =0
    count(/SERVERNAME/net.tcp.service[tcp,{HOST.CONN},{$MSSQL.PORT}],10m,"eq",1) =0​
    • Hamardaban
      • May 2019
      • 2714
      • techmattr
        • Sep 2022
        • 39
        Hamardaban, thanks the first expression you posted worked exactly how I wanted. Could you explain how the two expressions you posted would behave differently? It isn't immediately obvious to me how the second expression you posted would work.
        • Bartosz Mickiewicz
          • Oct 2022
          • 27
          Instead of "last" try "sum".
          Expression Description
          sum(/host/key,10m) Sum of values in the last 10 minutes.
          sum(/host/key,#10) Sum of the last ten values.
          So something like this:
          sum(/SERVERNAME/net.tcp.service[tcp,{HOST.CONN},{$MSSQL.PORT}],10m) =0
          This expression will trigger only when for 10 consecutive minutes your DB will be down (is running and accepting TCP connections) .​
          Count expression counts a number of values within the defined evaluation period.
          count (/host/key,(sec|#num)<:time shift>,<operator>,<pattern>)​​
          Supported operators:
          eq - equal (default)
          ne - not equal
          gt - greater
          ge - greater or equal
          lt - less
          le - less or equal
          like - matches if contains pattern (case-sensitive)
          bitand - bitwise AND
          regexp - case-sensitive match of the regular expression given in pattern
          iregexp - case-insensitive match of the regular expression given in pattern
          pattern (optional) - required pattern (string arguments must be double-quoted)​
          This would trigger when for the last 10 minutes a number of values greater than 0 equal 0.
          count(/SERVERNAME/net.tcp.service[tcp,{HOST.CONN},{$MSSQL.PORT}],10m,"eq",1) =0​​
          This would trigger when for the last 10 minutes a number of values equal to 1 is 0.
          Parameters with a hashtag have a different meaning with the function last - they denote the Nth previous value, so given the values 3, 7, 2, 6, 5 (from the most recent to the least recent):
          last(/host/key,#2) would return '7'
          last(/host/key,#5) would return '5'
            • 4924
            just sticking my nose in here..
            "count(/SERVERNAME/net.tcp.service[tcp,{HOST.CONN},{$MSSQL.PORT}],10m,"gt",0) =0"
            Lets count all values greater than 0 from last ten minutes and if result is 0, then we fire the trigger. This means, that only 0-s were found for 10 minutes, meaning your service is down for all that period. (net.tcp.service -> 0 - service is down, 1 - service is running)
            "count(/SERVERNAME/net.tcp.service[tcp,{HOST.CONN},{$MSSQL.PORT}],10m,"eq",1) =0​"
            Lets count all values equal to 1 from last ten minutes and if result is 0 (none found), then we fire the trigger. This means that no 1-s were found for 10 minutes, meaning your service is down for all that period.
