High level discovery of ESXi servers
  • slabber
    • Sep 2022
    I'm currently looking into using Zabbix to replace our aging monitoring systems. In our environment we have approx. 1000 ESXi servers deployed on bare metal. They are not connected centrally to a vCenter.
    Question: Is it possible to use a low-level discovery rule to discover ESXi hosts and then add them with a host template to start monitoring them and their attached VMs? I know I can add each ESXi server manually and then all VMs will be monitored, but adding 1000 ESXi machines individually is something I want to avoid.
    Thanks for the feedback!
  • Bartosz Mickiewicz
    • Oct 2022
    • 27
    This document is probably the thing you are looking for. It shows how to use discovery and how to automatically assign discovered hosts to groups and link templates.
