Database bloating
  • oNERa
    • Nov 2020
    Database bloating
    I am using Zabbix to monitor 245 hosts, all cisco switches. What actions would you recommend to keep the the database from bloating?
    Ubuntu 20.04.5 LTS
    Zabbix 5.2.7
    Values per second - 762.85
    Postgres v12
    I am already set up Autovaccum - is there any other actions/tasks i can perform to keep the DB lean as possible?
    245 hosts and 762 NVPS? You must be polling a lot of stuff, very often...
    Want to lean down your DB? Poll less..
    • Markku
      • Sep 2018
      • 1784
      In the short run the solution is to adjust the item intervals, as mentioned. That will keep the amount of new data tolerable.
      In the long run the usual solution is using database partitioning. That will make sure that old data will be efficiently deleted in chunks (instead of consuming resources while deleting old data one by one by the housekeeper, leaving gaps in the database). With PostgreSQL the usual way is to use TimescaleDB, there are instructions for that in Zabbix manual: https://www.zabbix.com/documentation...ll/timescaledb
      Markku
      • oNERa
        • Nov 2020
        Thanks for the ideas! i will install Timescale DB.
        in the meantime - is there any way to delete the content of database? (delete all the rows but not the DB Itself) , i am using postgresql 12
        • guille.rodriguez
          • Jun 2022
          • 120
          I think you are searching the truncate command
          https://www.postgresql.org/docs/curr...-truncate.html
          Be careful, I think you can trucante this tables
          • history
          • history_uint
          • history_str
          • history_text
          • trends
          • trends_uint
          That only deletes the collected data, not the definition of the items, etc
