My Proxies continually die
  • TecDragon
    • Nov 2019
    • 63
    Zabbix 6.2, Ubuntu 22.04 - MariaDB won't start on these with no good error. I found on another post to delete the /var/lib/mysql log files which works but only temporarily. The only resolution I have been able to find so far is to completely delete and re-install the proxy. Hoping someone may have ran into this and knows a better fix.
    I have rebuilt six of them so far, and more but different ones keep dying. I guess eventually I will have them all rebuilt.
    Does postgres have these issues? MariaDB for me atleast has been problematic.
    Click image for larger version  Name:	image.png Views:	0 Size:	38.9 KB ID:	452894
  • LinuxEngi
    • May 2018
    Are these each different Zabbix Proxy servers? Are you trying to run in HA, or just a bunch of proxies?
    If you are not running in HA you need to be using a separate MariaDB for each proxy. (Servers/Proxies cannot share a SQL database)
    If you are running in HA each proxy will need to be added as a node and HA Cluster will need to be configured accordingly
    • Markku
      • Sep 2018
      • 1784
      The first question I have: if you are not able to find out why your MariaDB "dies", why are you using MariaDB in the first place? Is there a reason you cannot use the SQLite3 variant of the proxy? It's easier to deploy and maintain.
      Otherwise you need to tell us more about your observations and configurations.
      Markku
      • TecDragon
        • Nov 2019
        • 63
        just picked what appeared to be the default and what I could find documentation on via the internet. MariaDB wont start on those proxies, the only error message is a benign one about the innodb, that when googled showed to be nothing. One article I read said to delete the innodb log file out of the /var/lib/mysql directory. That works... till the server reboots, then I have to delete it again, and the process continues in this manner. Rebuilding the proxy from scratch tends to fix it, was hoping maybe someone else had a similar issue and how did they fix it?
        • TecDragon
          • Nov 2019
          • 63
          Up to 7 dead today - these proxies will run along for months and then just die all with the same exact issue.
          Is sqllite more reliable? I will switch to using it. Or postgres however most of the documentation is written surrounding MariaDB
          • Markku
            • Sep 2018
            • 1784
            What does MariaDB say when it "dies"?
            Anyway, I still recommend using the proxy with SQLite3 unless you know you need something else. Install the zabbix-proxy-sqlite3 package and run these:
            sudo mkdir /var/lib/zabbix
            sudo chown zabbix.zabbix /var/lib/zabbix
            and set DBName=/var/lib/zabbix/zabbix_proxy in the proxy configuration file before starting the proxy.
            If/when upgrading the proxy later, delete the database file after stopping the proxy, before starting the new proxy.
            That's pretty much all you need to know to run it. No need to initialize any databases, the proxy will automatically create the database file whenever it is missing.
            Markku
            • TecDragon
              • Nov 2019
              • 63
              Markku First you normally are correct, and I appreciate you being on this forum. Thank you.
              Second, I am going to take your advice and just start rebuilding these with sqlite3, kinda sucks but whatevs.​
                • 4961
                You can also have that sqlite db on /dev/shm.. Might be faster, than on disk..
                • TecDragon
                  • Nov 2019
                  • 63
                  thanks cyber Markku
                  Anyway to just switch from MariaDB to sqllite3? I have tried on two of these and failed both times, even when I install the zabbix-sqllite and change the conf it still looks for mariadb and wont start.
                  • Markku
                    • Sep 2018
                    • 1784
                    I'm not a Ubuntu specialist but let's try:
                    sudo apt purge mariadb-server
                    sudo apt purge zabbix\*
                    Then follow the proxy installation instructions in zabbix.com download section.
                    Markku
                    • TecDragon
                      • Nov 2019
                      • 63
                      even after doing all of that I still get the above Markku thanks though for trying to help. It is like it have mysql embedded into it somewhere.
                      • Markku
                        • Sep 2018
                        • 1784
                        Can you show us the commands you used for installing Zabbix after the commands I showed you?
                        Markku
                        • TecDragon
                          • Nov 2019
                          • 63
                          Markku It didn't make sense, if I purged both they shouldn't exist - so - I just did the whole process over again and it worked. I must have missed a step.
                          Ubuntu 22.04
                          Purge Maria DB
                          sudo apt-get purge mariadb-*
                          sudo apt autoremove
                          sudo reboot
                          Then ran through the steps, to reinstall the zabbix proxy with sql-lite and it works.
                          Thanks! that will save me a batch of time. ​
                          I kind of feel bad about removing MariaDB but if SQLLite winds up being more reliable and easier to maintain then - party time.
                            • 4961
                            SQlite is good for up to some 5-600 NVPS. Over that it may start lagging. Housekeeper starts to take time etc.. Does not really help after that, if you throw a bunch of hardware on it or not... it is just internally not keeping up with amount of data...
