Discovery Trigger - find() with multiple values
  • Epires
    • Oct 2022
    Good afternoon,
    We`ve been trying to create a trigger for a discovery item that checks its value is equal to a macro. And it worked fine with a “<>” comparison.
    However, we have a new value to be checked, and would like to add it to the same macro, in a way that it would not matter if it is one, two or three values to be compared. It would like as a regex comparison.
    Ex.:
    Macro = (abc|cdb)
    Item value = abc
    Trigger = itemValue = macro [true]
    Ex.2:
    Macro = (abc|cdb)
    Item value = jkl
    Trigger = itemValue = macro [false]
    Ex.3:
    Macro = (abc|cdb)
    Item value = cdb
    Is it possible, or is there a better solution for this?​
  • Markku
    • Sep 2018
    • 1784
    Sounds like you need the find() function using regexp operator: https://www.zabbix.com/documentation...ctions/history
    find(/myhost/mykey,,regexp,{$MY_MACRO}) = 1
    or something like that. Just make sure your macro value is set to the correct regex, for example ^(abc|cdb)$
    Markku
