Monitoring > Owverview
  • felipealves04
    • Mar 2016
    • 13
    In my initial overview screen the names of the hosts are on the horizontal they were so without changing any settings I want to put them upright again any idea how to do this?
  • Atsushi
    • Aug 2013
    • 2028
    This is reported bug.
    ZBX-10170 : Column names in Overview are not vertical
    Perhaps, this problem will fix at next release.
    Zabbix 3.0 can be displayed properly.
    • felipealves04
      • Mar 2016
      • 13
      this error occurs in google chrome version 49.0.2623.87?
      • Atsushi
        • Aug 2013
        • 2028
        Yes.
        The same problem occurs in chrome 49.0.2623.87.
        • roberts.andzans
          • Feb 2016
          • 20
          Update your browsers and this issue will disappear.
          You will always get better Zabbix performance, if your system and it's components are up-to-date.
          Rob
