Delete unwated items
  • xox
    • Jul 2022
    Hello
    I am using Zabbix 6.0.7 for monittoring my network devices. I have downloaded template from Zabbix Site.
    My problem is that when using this template, i have revieved lots of data for one device.
    How can i delete some unwanted data (latest data).
    example.: how to delete some interface which i dont want to monitor.
    PLEASE HELP
  • superlava
    • Nov 2021
    • 26
    If it's for a particular host, You can disable the item.
    If you want to disable the item for all the hosts which are using this template, You can disable the item in template.
