Error after upgrading from 3.4 to 6.0
  • jacktx
    • Aug 2018
    • 15
    Guys, after we updated zabbix from 3.4 to 6.0, we have this error in all dashboard maps, has anyone experienced this? The error is associated with items with triggers
    • Undefined offset: 42952 [zabbix.php:22 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerWidgetMapView->doAction() → CMapHelper::get() → CMapHelper::resolveMapState() → getSelementsInfo() → array_map() → {closure}() in include/maps.inc.php:720]
    • Undefined offset: 42998 [zabbix.php:22 → require_once() → ZBase->run() → ZBase->processRequest() → CController->run() → CControllerWidgetMapView->doAction() → CMapHelper::get() → CMapHelper::resolveMapState() → getSelementsInfo() → array_map() → {closure}() in include/maps.inc.php:720]
  • Atsushi
    • Aug 2013
    • 2028
    What version of PHP are you using? If you use Zabbix 6.0, you need to use PHP 7.2.5 or later.
    • jacktx
      • Aug 2018
      • 15
      Hi Atsushi !
      Thanks for you answer, but our version is this:
      '_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/
      php -v
      PHP 7.2.24 (cli) (built: Oct 22 2019 08:28:36) ( NTS )
      Copyright (c) 1997-2018 The PHP Group
      Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
      with Zend OPcache v7.2.24, Copyright (c) 1999-2018, by Zend Technologies
      If Its you want appreciate config.php it is attachments
      Regards
