Zabbix Server Failing in Docker container with exit code 1
  • wmead
    • Oct 2022
    I setup a POC VM system with OEL8.6 and created a docker compose file with Zabbix 6.2 on Postgres with a predefined Network and IP's and it was working perfectly. I tried moving the same docker compose file to an OEL8.6 Physical server with a bonded 10GB interface and I cannot get it to work. I am thinking this is a Docker issue but I am trying to get whatever Info I can from the logs from the server container but because it is restarting constantly I cannot get a command prompt in the container and when I start the containers up in no background mode the logs do not show me anything that I can go from.
    zabbix-server_1 | ** Database 'zabbix' already exists. Please be careful with database owner!
    zabbix-web_1 | 10.60.20.228 - - [20/Oct/2022:14:39:19 +0000] "POST /zabbix.php?sid=0f2462a83bb892a8&action=widget.item .view HTTP/1.1" 200 217 "http://prodjump6.aeso.ca/zabbix.php?action=dashboard.view" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36" "-"
    zabbix-server_1 | ** Table 'zabbix.dbversion' already exists.
    zabbix-server_1 | ** Preparing Zabbix server configuration file
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenIP": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenPort": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ListenBacklog": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SourceIP": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogType": 'console'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogFile": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogFileSize": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "PidFile": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DebugLevel": '1'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBHost": 'postgres-server'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBName": 'zabbix'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBSchema": 'public'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBPort": '5432'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VaultDBPath": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VaultURL": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBUser": 'zabbix'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBPassword": '****'. Enable DEBUG_MODE to view value ...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "AllowUnsupportedDBVersions": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartReportWriters": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "WebServiceURL": 'http://zabbix-web-service:10053/report'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageURL": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageTypes": 'log,text'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryStorageDateIndex": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "DBSocket": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StatsAllowedIP": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPollers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartIPMIPollers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPollersUnreachable": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartTrappers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPingers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartDiscoverers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartHistoryPollers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartHTTPPollers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartODBCPollers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartPreprocessors": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartTimers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartEscalators": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartAlerters": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartLLDProcessors": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "JavaGateway": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "JavaGatewayPort": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartJavaPollers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartVMwareCollectors": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareFrequency": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwarePerfFrequency": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareCacheSize": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "VMwareTimeout": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SNMPTrapperFile": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartSNMPTrapper": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HousekeepingFrequency": '1'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "MaxHousekeeperDelete": '5000'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ServiceManagerSyncFrequency": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SenderFrequency": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "CacheSize": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "CacheUpdateFrequency": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartDBSyncers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryCacheSize": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HistoryIndexCacheSize": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrendCacheSize": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrendFunctionCacheSize": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ValueCacheSize": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "Timeout": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TrapperTimeout": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnreachablePeriod": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnavailableDelay": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "UnreachableDelay": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "AlertScriptsPath": '/usr/lib/zabbix/alertscripts'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ExternalScripts": '/usr/lib/zabbix/externalscripts'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "FpingLocation": '/usr/bin/fping'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "Fping6Location": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSHKeyLocation": '/var/lib/zabbix/ssh_keys'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LogSlowQueries": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "StartProxyPollers": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ProxyConfigFrequency": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "ProxyDataFrequency": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLCertLocation": '/var/lib/zabbix/ssl/certs/'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLKeyLocation": '/var/lib/zabbix/ssl/keys/'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "SSLCALocation": '/var/lib/zabbix/ssl/ssl_ca/'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "LoadModulePath": '/var/lib/zabbix/modules/'...updated
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCAFile": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCRLFile": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCertFile": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherAll": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherAll13": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherCert": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherCert13": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherPSK": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSCipherPSK13": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSKeyFile": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSPSKIdentity": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "TLSPSKFile": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "HANodeName": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "NodeAddress": ''...removed
    zabbix-server_1 | ** Updating '/etc/zabbix/zabbix_server.conf' parameter "User": 'zabbix'...updated
    zabbix-server_1 | Starting Zabbix Server. Zabbix 6.2.3 (revision 98ee88f).
    zabbix-server_1 | Press Ctrl+C to exit.
    zabbix-server_1 |
    zabbix-server_1 | 7:20221020:143919.784 Starting Zabbix Server. Zabbix 6.2.3 (revision 98ee88f).
    zabbix-server_1 | 7:20221020:143919.784 ****** Enabled features ******
    zabbix-server_1 | 7:20221020:143919.784 SNMP monitoring: YES
    zabbix-server_1 | 7:20221020:143919.784 IPMI monitoring: YES
    zabbix-server_1 | 7:20221020:143919.784 Web monitoring: YES
    zabbix-server_1 | 7:20221020:143919.784 VMware monitoring: YES
    zabbix-server_1 | 7:20221020:143919.784 SMTP authentication: YES
    zabbix-server_1 | 7:20221020:143919.784 ODBC: YES
    zabbix-server_1 | 7:20221020:143919.784 SSH support: YES
    zabbix-server_1 | 7:20221020:143919.784 IPv6 support: YES
    zabbix-server_1 | 7:20221020:143919.784 TLS support: YES
    zabbix-server_1 | 7:20221020:143919.784 ******************************
    zabbix-server_1 | 7:20221020:143919.784 using configuration file: /etc/zabbix/zabbix_server.conf
    prod_zabbix-server_1 exited with code 1​
  • Markku
    • Sep 2018
    • 1784
    Unfortunately I haven't used Zabbix in containers very much so I cannot help you in those specifics, but just an idea. In a normal Zabbix server installation the next line after the configuration file name is the database version:
    93758:20221020:202522.684 ******************************
    93758:20221020:202522.684 using configuration file: /etc/zabbix/zabbix_server.conf
    93758:20221020:202522.691 current database version (mandatory/optional): 06020000/06020002
    93758:20221020:202522.691 required mandatory version: 06020000
    93759:20221020:202522.695 starting HA manager
    93759:20221020:202522.698 HA manager started in active mode
    93758:20221020:202522.699 server #0 started [main process]
    ​So are you sure your database is working normally?
    Markku
    • wmead
      wmead commented
      Hello Markku, I am quite sure that the DB is working properly as I am using the exact same docker-compose file that I did on my test OEL8 VM system and everything works just fine in that setup.
  • wmead
    • Oct 2022
    Hello Markku I definitely owe you an apology as when I was looking into this some more I noticed that the Docker Compose file was using the latest images for the Server and the Postgres Database. In my working version it was using Server 6.2.1 and Postgrest 14.5.
    I modified the compose file to use the 6.2-latest image of the Server and verison 14.5 for Postgres and now it is working fine. So there was definitely something going on between the server and the Databse.
