Hi everyone,
Currently I am working on a project and I have to discover a full Azure environment. When discovering I make an API call where I ask for all virtual machines in one discription. Sadly not all devices fit in that one API call and I get a nextlink property returned. This next link property is a link that gives you the option to get the next list of virtual machines by giving you a link that has a skiptoken. This token identifies what the last resource was in the first page so that only new resources are displayed. Now it is possible that the same events occurs more than once. Example: page one return nextlink, page 2 returns next link and so on... Is there a way to get that nextlink into a variable without a script so that I create an item that uses a http poller where I can use that variable so every next page get pulled.
Regards
Regards
