Run script on Host A from Item on Host B
  • greavette
    • Jul 2015
    • 82
    Hello Forum,
    I have a scenario where I monitor my CyberPower UPS devices over the network using Zabbix. There is an item called 'Remaining Runtime' for my UPS Host.
    I also have a server that is connected to the above UPS. In the event of a Power Failure I want to shutdown this server before the battery runs out.
    I would like to execute a script when the 'Remainting Runtime' item is below a threshold where the script will be executed on my server connected to that UPS.
    Does anyone have an example or a post I can follow on how to set up this type of scenario?
    Thank you.
  • Markku
    • Sep 2018
    • 1784
    Hi, basically you want to create a script and an action that executes the script on the server when your conditions are met.
    Actions: https://www.zabbix.com/documentation...remote_command
    Scripts: https://www.zabbix.com/documentation...ration/scripts
    Markku
