Hi all,
i am trying to create graph regarding Memory Usage (Template OS Linux).. so i have two item which are related to Memory graph . One is Available memory and second is Total memory.
The problem is that i see Available memory line but i dont see Total memory line .. settings are the same for both
But when i change settings for Total Memory form Bold line to Gradient line i can see it on graph. Gradient line works but any other option does not work..
where can be the problem?
Thanks in advance
Boris
Thanks in advance
Boris
