Use Macro "PROXY.NAME" in Problem Tags
  • tiroso
    • Oct 2022
    Hello and good evening,
    I'm using Zabbix and Zabbix Proxy for many customer systems and monitoring everytime the same metrics...but for different customers. So I created a template and use it for all these Customer System Hosts.
    Now I want to set up "Services" and track some SLAs for these customer Systems.
    I have set it up correctly, but it reacts on the problem tags from each customer. So I would set it up and react on the tags based on each proxy.
    But now I got struggeling to use the macro PROXY.NAME in problem tags.
    Is there anybody with the same problem or maybe a solution for this? I hope i could describe it detailed enough
    Have a nive evening
    Tiroso
