Migrating users/groups
  • RoyK
    • Jan 2016
    • 22
    Hi all
    I have an old zabbix server, v5, and a new one, v6. After several issues migrating templates (the new ones had different names and just migrating was problematic), we chose to setup a new system from scratch. Migrating the config seems to be easy, but not the users/groups. Authentication is done by LDAP, so no issues with passwords, those few local accounts that exists can be recreated manually. But - how can we export/import the users and groups? I have asked around and it seems the answer is 'Use the API', but since that seems to be a long shot, is there anything readymade to do this without reinventing this wheel?
    roy
  • marco.lima
    • Aug 2020
    I sympathize with you. I went through the same issue during the pandemic when we had to rebuild our setup from scratch. I also toyed with the idea of using the API but didn't go through with it.
    I suppose you could consider doing a direct copy from your old database to the new one...provided you map out the necessary table dependencies and such....
    Here's what I did:
    - I called our intern over and said: "Guess what you'll be doing for the next couple of days...? *wink* *wink*" (it took him 3 recreate 125 users lol)
    • RoyK
      • Jan 2016
      • 22
      Give me a day or two and we'll post the code to do it the api way
        Table structures are identical I think... (4.4 vs 6 are, so I assume 5 there in between is also the same)... export data from old db, import to new...
        for postgres from one host to another...
        psql -tc "COPY (SELECT * FROM users) TO STDOUT DELIMITER ',' CSV" zabbix | psql postgresql://zdbuserasswd@dbhost:5432/zabbix -c "COPY users FROM STDIN CSV;"
