Change SNMP LLD values
  • derdeagle
    • Dec 2016
    When using LLD via SNMP a JSON like the following is returned (modified because the log didn't show the full string).
          "{#SNMPINDEX}":"14",
          "{#FAN}":"temperature"
          "{#SNMPINDEX}":"17",
          "{#FAN}":"cpu-temperature"
          "{#SNMPINDEX}":"20",
          "{#FAN}":"fan1-speed"
          "{#SNMPINDEX}":"21",
          "{#FAN}":"fan2-speed"
          "{#SNMPINDEX}":"22",
          "{#FAN}":"fan3-speed"
          "{#SNMPINDEX}":"23",
          "{#FAN}":"fan4-speed"
    I only want the fans to be returned, so I added a filter filtering "{#FAN} = ^fan[0-9]+-speed$". That work's as expected.
    What I could not achieve by trying out myself or search on the forum etc. was changing the name from e.g. "fan1-speed" to "Fan 1".
    How can I change those LLD macro values?
    Thanks in advance.
  • Answer selected by derdeagle at 28-10-2022, 19:42.
    markfree
    • Apr 2019
    • 872
    There's a catch with item keys.
    Note, that commas are not allowed in unquoted item key parameters, so the parameter containing a macro function has to be quoted. The backslash (\) character should be used to escape double quotes inside the parameter.
    Try it like this:
    fan.speed["fan{{#FAN}.regsub(\"fan([0-9]+)-speed\",\1)}"]
    Do you really find it necessary to extract the fan number to use it at the key parameter? Wouldn't the macro value itself be enough?
    • markfree
      • Apr 2019
      • 872
      Macro functions could be helpful for your discovery.
      What if you tried something like this?
      {{#FAN}.regsub("fan([0-9]+)-speed",\1)}
      In my testing, I managed to extract the number from an LLD macro value and use it in the name field.
      • derdeagle
        • Dec 2016
        Your suggested way indeed works for the name but unfortunately not for the key.
        I was able to set the name to the following value:
        Fan {{#FAN}.regsub("fan([0-9]+)-speed",\1)} speed
        If I now want to set the key to the following value I get the error message afterwards:
        fan.speed[fan{{#FAN}.regsub("fan([0-9]+)-speed",\1)}]
        Invalid key "fan.speed[fan{{#FAN}.regsub("fan([0-9]+)-speed",\1)}]" for item prototype "Fan {{#FAN}.regsub("fan([0-9]+)-speed",\1)} speed" on "Template Mikrotik CCR2116-12G-4Splus": incorrect syntax near "+)-speed",\1)}]".
        According to the fine manual the macro function should also work in the key.
        Btw. I am using version 6.0.9 if that is of interest.
        • markfree
          • Apr 2019
          • 872
          Try it like this:
          • Markku
            • Sep 2018
            • 1784
            I would definitely keep the original string that was present in the discovery data, that will help hugely when someone looks at the items and the discovery data later. Just my 2 cents
            Markku
            • derdeagle
              • Dec 2016
              That is now working as intended, thank you very much.
              It is not necessary at all and both if you are 100% right. This should not be done in general. As this is solely for me privately let's just declare it as learning Nevertheless I do think about just using the value (fan1-speed) as the key as this will be unique, too.
