Zabbix : How to Create a screen using data(graph) from Latest Data
  • jay5c
    • Mar 2016
    • 16
    I have used a filter to get CPU usage time from various hosts on my VM. The issue is after I get the stacked graph, how to I place it to screen ?
    Thank You
    - Jay
  • roberts.andzans
    • Feb 2016
    • 20
    First of all go to Configuration-->Hosts or Templates-->Graphs-->Create graph
    Add items you need, choose stacked option at graph type and fill all needed fields there
    After you have created graph go to Monitoring-->Screens-->Create screen
    After you have created your screen click on Constructor and when Constructor page opens press Change, find your graph and Add it.
    Rob
