Help with source of error in Zabbix log
  • JPinNC
    • Aug 2022
    Version : zabbix_server (Zabbix) 5.0.28
    O/S : Ubuntu
    Background: Inherited Zabbix setup and have no experience with it. Trying to learn but encountering the following issue.
    The following message is in my Zabbix log (located in /var/log/zabbix) :
    2022-10-30 15:19:40 main ERROR Failed processing item 'postgresql.txn_time[5432,postgres]'.
    Originally I thought this might be associated with what I was seeing in the Zabbix dashboard under Configuration->Hosts->hostname->Items. So I disabled the Item but continued the to receive the messages in the error log every 10 seconds.
    If somebody can point me to the answer or, better yet, the relevant documentation I would greatly appreciate it. If there is additional information I need to provide please let me know that.
    Thank you
    agent log? server log? was that disabled item the only instance? From disabling to stopping it may sometimes take a long time, if conf updates are set to long period...
    That key is not part of official integration (https://www.zabbix.com/integrations/postgresql), I think. So its some local self made template ?
