SLA report using SQL query
  • Vermizz
    • Oct 2022
    • 33
    I need to extract historical data from events along with their closing time (durration time) for a given host_group and selected tag. I wrote a SQL query, that pulls all the data, for me but I can't calculate the durration time against the e.clock column.
    I know, I should do diffdate on e.clock if e.value changes from 1 to 0 then subtract e.clock for r_eventid - eclock for source eventid.
    I tried to use API but also don't know how to calculate durration time for resolved event.
    How zabbix calculates the duration time for resolved event?
    Does anyone know how to modify my query to get 3 additional column: start problem time, resolve problem time and duration time?
    For workaround problem, I use GUI: Problems-> History-> Export to csv (button) but I want to automate this task.​ Can I somehow schedule this export​?
    select h.hostid, i.itemid, i.NAME AS iname, f.triggerid, FROM_UNIXTIME(e.clock)AS eclock, e.eventid, e.objectid, e.VALUE, er1.r_eventid
    #h.NAME, a.subject, FROM_UNIXTIME(a.clock) AS aclock
    from hosts h join items i on i.hostid = h.hostid
    join functions f on f.itemid = i.itemid
    join events e on e.objectid = f.triggerid
    join triggers t on f.triggerid = t.triggerid
    join hosts_groups hg On h.hostid = hg.hostid
    JOIN item_tag it ON i.itemid = it.itemid
    left JOIN alerts a ON a.eventid = e.eventid
    left JOIN event_recovery er1 ON e.eventid=er1.eventid
    WHERE
    e.clock > UNIX_TIMESTAMP(DATE_SUB(CURDATE(),INTERVAL 6 MONTH)) AND
    hg.groupid = 252 AND
    it.value IN ('ICMP', 'Zabbix agent') AND
    i.NAME IN ('Agent ping', 'ICMP ping') AND
    e.value in ('0','1')
    #AND a.eventid = e.eventid
    order BY
      e.clock DESC
    LIMIT 200;
  • ridonekorkmaz
    • Jun 2023
    We wanted to do same thing. We were only achieved to write a query that event_id, start_event_time, recovery_event_time on the same row. But we could not able to add hosts, objects etc.
    Your query helped us too much, thank you posting your it here.
    Finally we managed to write SLA report combining both queries.
    We post here, may be helpful for someone.
    Note: WHERE condition must be changed according your needs.
    -- Final report (SLA Report)
    select q.host_name,
    q.ip,
    q.location,
    q.item_name,
    q.triggerid,
    q.trigger_name,
    sum(recovery_duration_seconds) sum_recovery_duration_seconds
    from
    (select distinct h.name as host_name,
    ifc.ip,
    hi.location,
    i.name as item_name,
    f.triggerid,
    e.objectid,
    e.eventid,
    er1.r_eventid,
    e."name" as trigger_name,
    case e.value
    when 1 then 'RESOLVED' when 0 then 'PROBLEM' end as "status",
    to_timestamp(e.clock) as start_time,
    to_timestamp(e2.clock) as recovery_time,
    case when e2.clock is null then (extract(epoch from now()) - e.clock) when e2.clock is not null then ((select clock from events e2 where e2.eventid = er1.r_eventid) - e.clock) end as recovery_duration_seconds
    from hosts h
    join items i on (i.hostid = h.hostid)
    join functions f on (f.itemid = i.itemid)
    join events e on (e.objectid = f.triggerid)
    join triggers t on (f.triggerid = t.triggerid)
    join hosts_groups hg on (h.hostid = hg.hostid)
    join item_tag it on (i.itemid = it.itemid)
    left join alerts a on (a.eventid = e.eventid)
    left join event_recovery er1 on (e.eventid = er1.eventid)
    left join events e2 on (e2.eventid = er1.r_eventid)
    left join interface ifc on (ifc.hostid = h.hostid)
    left join host_inventory hi on (hi.hostid = h.hostid)
    where hg.groupid = 252
    and it.value IN ('ICMP', 'Zabbix agent')
    and i.name IN ('Agent ping', 'ICMP ping')
    and e.value in ('0', '1')
    ) q
    group by q.host_name, q.ip, q.location, q.item_name, q.triggerid, q.trigger_name
    order by 7 desc, 2, 3, 4, 5, 6
    -- Raw data, for check, to be sure
           ifc.ip,
           hi.location,
           f.triggerid,
           e.objectid,
           e.eventid,
           er1.r_eventid,
           case e.value
                 end as "status",
           case
                                                            (select clock
                                                             from events e2
      from hosts h
      join items i
      join functions f
      join events e
      join triggers t
        on h.hostid = hg.hostid
      join item_tag it
        on i.itemid = it.itemid
      left join alerts a
        on a.eventid = e.eventid
        on e.eventid = er1.eventid
      left join events e2
        on e2.eventid = er1.r_eventid
        on ifc.hostid = h.hostid
        on hi.hostid = h.hostid
     order by 7 desc, 2, 3, 4, 5, 6​
    • Vermizz
      • Oct 2022
      • 33
      Thanks for submitting the SQL query. Greate job
      Personally, I finally did it using the API and a Python script.
      Script available on my github: https://github.com/Vermiz/Zabbix/tre...eports/KPI_SLA
      • ridonekorkmaz
        • Jun 2023
        Thank you for sharing, great. We need a modification, so instead of modifiying SQL, we will use your Python script, if you kindly have consent.
