Howto help: Using Zabbix 6.2 to publish Service status on a simple web page
  • Wolfsbane2k
    • Nov 2022
    • 55
    Hi All.
    I'm currently investigating using Zabbix to monitor a number of processing chain of applications and network devices, each with their status reported via a mix of SNMP and zabbix agents.
    I'm currently going through the process to aggregate these up into a service (i.a.w 8. Service monitoring (zabbix.com)​ , but I then need to publish that live service status onto a dedicated webpage where a 3rd party can query & scrape it to ingest into their system via xml, json, or other similar web based format.
    I've had a look through the user manuals and a zabbix book, as well as the integration pages; i believe the closest that I am likely to get is the 7 Real-time export of events, item values, trends (zabbix.com)​ but this seems to be host and problem specific, rather than supporting service.
    Is it possible to configure Zabbix to export a specific (named) service status in this way? If so, is anyone able to point me in the right direction?
    Thanks in advance!
    W
