Multiple snmp communities, same host
  • Eduardo Tacara
    • Nov 2022
    I need to monitor Cisco device with vrf, each vrf aswers with a different community, for example:
    default community: abcd
    vrf prod = community abdc-prod
    vrf dev = community abcd-dev
    This community+vrf configuration is automatic from the Cisco device.
    Zabbix 4.2 is possible to configure it direct in Items or Discovery. Zabbix 6 there is no option for comminity in items.
    Zabbix 4:
    Zabbix 6:
  • Eduardo Tacara
    • Nov 2022
    Any suggestion?
    • tim.mooney
      • Dec 2012
      • 1436
      Even without paid support, you can submit bugs and enhancement requests to the Zabbix bug tracker at https://support.zabbix.com
      Since this was a feature in a previous version and it no longer works, a polite bug report might get them to look into adding it back.
      I haven't tried this, but is it possible at 6.x to create multiple Zabbix 'host' entities that map to the same host, and then assign some SNMP items to one host and some SNMP items to the other host? I'm skeptical how well that will work, but it might be worth experimenting with it.
        Where did you set that macro in v4? Host level? Template level?
        • Markku
          • Sep 2018
          • 1784
          What I did as a quick'n dirty solution:
          - created multiple SNMP interfaces for the host in Zabbix (with different community strings per VRF, as configured on the switch)
          - created per-VRF discovery rules for the host
          - assigned each discovery rule the correct SNMP interface.
          The only better solution I had in mind was to create the configs programmatically via Zabbix API. But I haven't had a business case for that yet so I have managed with the manually copied (and edited) discovery rules for now.
          I'm open for better suggestions.
          Markku
          • jacek
            • Nov 2008
            • 45
            Markku
            Is there a way to handle this via template somehow? Looks like a headache to set this up on every host.
            • Markku
              • Sep 2018
              • 1784
              Yes, I created the discovery rules in a template and attached it to all the routers that had the same set of VRFs.
              Markku
              • Pursuit
                • Mar 2023
                Markku
                Hi!
                In your template, how did you manage to associate the different discovery rules with specific host interfaces? There doesn't seem to be any "Host interface" field in templates.
                Sure, it's possible to change the host interfaces after applying the template, but you'd need to do that for each item prototype inside your discovery rules, which would be... Less than ideal.
