HTTP agent and JSON with multiple data points
  • nabberuk
    • May 2010
    • 82
    I have an API with the following data that i would like to feed into Zabbix. The idea is to grab data every 24 hours, the data contains
    [ { "name": "G", "unit": "kW", "data": [ [ "2022-11-03T00:00:00.000Z", 0 ], [ "2022-11-03T02:00:...
    I have a master host that grabs the json file and I'm just at creating dependants. Now i could use jsonpath to grab individual data but there are multiple rows of data. I'm a little unsure on how to do this.
    I would be expecting each name G, I etc to be its own item and then each row under data to be entered with the data and date.
    ​Lets assume you have a master item...
    Now create a discovery, which is "dependent" on that json LLD macro "{#NAME} -> $.name" (and for unit if you wish, can use it in item prototype unit field.. )
ID:	453955 Click image for larger version
    now add item prototype to that discovery ... again, dependent on the same master item. key -> data[{#NAME}], name as you need it, "#NAME_data" for example... add preprocessing "JSONPath -> $[?(@.name == '{#NAME}')].data[0].[1].first()"
ID:	453957 Click image for larger version
    This shoudl end up with items like this...
    ​ ​ ​nice and colorful... updates each time your master item updates...
    • nabberuk
      • May 2010
      • 82
      Would this handle the fact that there is more than a single bit of data for each item when the master item makes the call?
      I'm also just testing and getting a "Cannot send request: wrong discovery rule type." error.
      • nabberuk
        • May 2010
        • 82
        Ignore the error, i was doing check now on the dependant item and not the master one.
        From the looks of it, it will only grab the last entry and not all of them, beginning to wonder if the only way achieve this is via javascript but even then i'm not sure i can add values with their respective datetime
          Yes it grabs last data point. but if you run it each day, you don't need previous ones, as they are already present... Dependent items are not working this way, that you feed unknown amount of values to them at once and next time it should somehow understand, which ones are already present??... You can of course change data type to text and grab whole that data[] as one data point... but what will you do with it after that?
          • nabberuk
            • May 2010
            • 82
            The main reason is the data is only updated every 24 hours, so its always 24 hours out of date.
            I'm now investigating a python script and Zabbix sender as it seems i can specify the time of each value.
