Zabbix Database upgrade ?
  • chandra22
    • Feb 2016
    • 13
    Hi Guys,
    I have upgraded the Zabbix from 2.4.7 to 3.0 (upgrade completed fine)
    After the upgrade i have started the Zabbix server, but its showing as not running.
    sudo /etc/init.d/zabbix-server start
    * Starting Zabbix server zabbix_server
    sudo /etc/init.d/zabbix-server status
    * zabbix_server is not running
    Its been around 2 hours. I am not sure whether it still upgrading the Database or the Database upgrade process not started at all ?
    # tail /var/log/zabbix/zabbix_server.log
    32155:20160330:122018.863 poller #45 [got 10 values in 0.342636 sec, getting values]
    32148:20160330:122018.863 poller #38 [got 10 values in 0.351091 sec, getting values]
    32129:20160330:122018.863 poller #19 [got 9 values in 0.344776 sec, getting values]
    32159:20160330:122018.863 poller #49 [got 10 values in 0.344905 sec, getting values]
    32126:20160330:122018.863 poller #16 [got 9 values in 0.350108 sec, getting values]
    32136:20160330:122018.864 poller #26 [got 8 values in 0.336054 sec, getting values]
    32149:20160330:122018.864 poller #39 [got 12 values in 0.354949 sec, getting values]
    32134:20160330:122018.864 poller #24 [got 1 values in 0.365587 sec, getting values]
    32105:20160330:122018.864 zbx_on_exit() called
    32150:20160330:122018.864 In get_values()
    I can't find any logs written since the Zabbix server upgrade process started.
    Could you please let me know how to check if the Database upgrade process started or not ?
    why its not writing to log file or i need to check something else
    MySQL Database size: 120GB
    its located in different server and zabbix user have full permissions. .Config file got correct details
    Zabbix front-end error message "–The frontend does not match Zabbix database. Current database version (mandatory/optional): 2040000/2040000. Required mandatory version: 3000000. Contact your system administrator.
    Thank you
  • chandra22
    • Feb 2016
    • 13
    Its still the same its been 5 hours since the Zabbix upgraded to 3.0
    Restarted the Zabbix server service number of times - no use
    increased "StartPollers" value
    Rebooted the server as well - no luck
    when i tried to restart the Zabbix server service - its not even starting for a sec, as well. and its not giving any error as well.
    As the Zabbix log file not updated since i started the upgrade process, I am not understanding what to check now
    OS: Ubuntu 14.04.4 LTS
    Thank you
    • roberts.andzans
      • Feb 2016
      • 20
      Zabbix front-end error message "–The frontend does not match Zabbix database. Current database version (mandatory/optional): 2040000/2040000. Required mandatory version: 3000000. Contact your system administrator."
      hey!
      Have you checked, if your DB version is compatible with new Zabbix 3.0?
      Here I found some info in - https://www.zabbix.com/documentation...n/requirements
      • roberts.andzans
        • Feb 2016
        • 20
        Some notes on your issue:
        1. Do not use DebugLevel=4, because it gives redundant information. Instead DebugLevel=3 is good enough
        2. Is is good to use two SSH sessions. In one you do your actions and in second use tail -f for your zabbix-server.log to monitor your current progress
        3. Zabbix front-end error message "–The frontend does not match Zabbix database - shows that your frontend is upgraded to 3.0, but zabbix-server-mysql is still on old version.
        When you will upgrade zabbix-server-mysql to 3.0 this message will disappear
        -Rob-
        • chandra22
          • Feb 2016
          • 13
          Hi Guys,
          Thanks for your help.
          As i mentioned in my previous response, my initial attempt failed when trying to upgrade to 3.0
          - I have used command "apt-get upgrade". This may be wrong to use ....
          - choose to keep old Config files at the time of upgrade
          Not sure what went wrong, after the upgrade the service was not starting at all, after number of attempts I have rolled it back. (restored the Zabbix server snapshot - thanks to virtualisation).
          On my second attempt, I have followed below procedure
          - I ran the Ubuntu update first
          - used cmd "sudo apt-get install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent -y"
          - choose to overwrite Config files at the time of upgrade
          Not sure which option resulted successful upgrade. Now everything working fine and good. later updated the "zabbix_server.conf" file using our own values.
          Perfect now. Welcome to 3.0
          Regards,
