Active checks Fatal error. Internal CLR error. (0x80131506)
  • EdgarGR
    • Nov 2022
    We have a bunch of servers being monitored by zabbix and it really works fine.One day, all of a sudden, an item stopped working on a host.
    I tried reinstalling zabbix-agent and different versions of it and always the same problem.
    The error:
    Aborted (core dumped)
    At the logs nothing appears:
    sudo tail /var/log/zabbix/zabbix_agentd.log
    70146:20221107:132136.433 IPv6 support: YES
    70146:20221107:132136.433 TLS support: YES
    70146:20221107:132136.433 **************************
    70146:20221107:132136.433 using configuration file: /etc/zabbix/zabbix_agentd.conf
    70146:20221107:132136.434 agent #0 started [main process]
    70151:20221107:132136.435 agent Home started [collector]
    70152:20221107:132136.436 agent Forum started[listener #1]
    70153:20221107:132136.437 agent #3 started[listener #2]
    70154:20221107:132136.438 agent #4 started[listener #3]
    70155:20221107:132136.438 agent #5 started [active checks #1]
    The item itself:
    -User parameter for Linux.
    -It just returns 1 or 0.
    -Working on all the other servers
    -Before it was working.
    Any idea on how can I solve it or what's this error about?
